Hi Guys,
New to the site as I hear someone may be able to shed some light on a few questions i have burning!
I am about to undertake fitting a new kitchen and thought I'd save a couple of thousand pounds doing it myself. Fairly competent at most things and if I get a good explanation, its normally enough to get me through.
The oven going in is a Samsung BQ1ST077.
Spec is:
Input Voltage / Frequency 230V ~ 50Hz
Output Rating max.3650W
Cable to be 1.5~2.5 mm2
I understand it needs to be hard wired in to the mains supply using a 'Multi Pole Isolator Switch', but heres the thing...
I have a spare RCD in my fuse box thats always off. (it was an old shaver point when I took down the bathroom wall. I made safe the cable with the view of maybe needing it in the future.
Is this going to be ok to use for the oven? Its a thick cable but unsure what is measured? it has a 15mm outer but the actual cores are 5mm eachh with a single earth.
If I can use this for the oven, I believe I then need to go in to a 'fused spur'? Is this what is also know as a multi pole isolator?
Looking at these today in B&Q and realised I have no Idea what AMP I need? Where could I find this?
Thanks in advance for your time...
Phil
Spec is:
Phil
