i have a single pipe system does anybody know if its possible to add an extra rad by just connecting it to the flow and return on a gravity fed system
Well if it`s just a back boiler to a coal fire - and it`s a direct system ( no header tank in loft) you`ll need a 3/4 tapped cast iron wall mounted rad - commonly fitted to rayburns - and I just happen to have one I took outhi doitall the single pipe system only as one rad i want to add another rad but the distance between the rad whats in to the new one is about 12 foot and it cant be run in 28m pipe only 15m its a coal fire with a flow and return and also does the hot water ,through the tank can i just run 15m pipe to the flow and return of the back boiler any comments would be great![]()
