When earthing the armour in SWA what size should it be? do you earth it with 4mm cable?
It should be at least half the size of the main conductors and a minimum of 2.5mm cu if mechanically protected, and 4mm cu if not mechanically protected.
The SWA is only for the cable protection and there is one core in all of them that provide the earth.
The SWA still has to be earthed.
Against what?Yes I know... I was just telling you all what the SWA did etc so you could tell me if 4mm will be OK just to protect the armour.
