Hello all,
I am trying to add a second phone point from my Virgin Media master socket.
On the back of the master socket it has be numbers 1-6, but there are only 4 connectors. Thinking they would be in fact 2 -5 I wired up the second one as such. However it doesn't work at all.
I used wire from an extension kit as I Wickes had that in stock but not "naked" cable without plugs at each end. I assume that wire would be ok?
I have tried two different wires to see if that was the problem but it wasn't. I have managed to wire eight Ethernet ports today, using a proper Krone tool so an confused as to why the phone doesn't work.
I have put some photos here.
http://www.diynot.com/network/IanWood/albums/11552
Is there something else I need to do?
Could the master socket itself to broken?
Any help would be most appreciated.
Cheers
Ian
Cheers
Ian
