Found a no on side c6065a1317
Glow worm ultimate. were will model num be.
Boiler bout 10yr old
Return pipes above boiler not hotIf boiler is firing and staying lit, then that heat has to be going somewhere! Common mistake to assume the pump is working, it may be running but that doesnt always mean its actually moving any water! Check small tank in loft has water in it, accessible pipework, see how far the hot water is getting, and any motorised valves are operating correctly.
