Vaillant combi boiler, cant find model number it looks old aprox 1991 i think. Called engineer out as the hot water tap in kitchen doesn't always come out hot and boiler doesn't turn on, but if i leave the hot tap on in kitchen , run to bathroom run hot tap, boiler then fires up. Engineer said the kitchen tap is faulty needs replacing, nothing to do with the boiler, he refilled boiler with water as pressure was low (needs this doing at least once a year) then he said there is a leak at bottom of boiler i think its the diverter valve?? not sure what its called, slight water drip coming from the top of the block where 2 pipes go to boiler and another 2 pipes go out. The engineer then said it would be expensive to repair 300.00 parts and started talking about new system which would mean ripping the kitchen out. The boiler works very well and previous engineers have said doesn't need to be replaced. Can anyone tell me how i can find out the model number or confirm the part that needs repair/replacing as i would like to be able to phone around and check prices etc.
Thank you
Thank you
