does an rcd need a earth connection tt system to operate properly,
or will mit not operate at all
also does the imbalance travel to earth,
i have a rcd tester i bought pretty basic detects earth and phase neutral reversal etc.
you plug it in to a pc outlet then you can also test the rcd by causing a 10ma to 30ma fault it works when there is a earth present!! not when there is no earth
what is it actually doing
