I have a Buderus 500-24/C condensing boiler.
It has a Boulter Buderus Modulink 250 RF wireless thermostat / programmer connected to it on to the terminals marked "Room Thermostat".
I want to use a different programmer (a Potterton EP 5002) because I want to be able to set different heating times per day, rather than just one set of times that is repeated all through the week and on weekends.
I've wired the Potterton Programmer to the connection inside the boiler marker "Programmer 230V". I'm sending Live and Neutral out to the Programmer and I'm receiving "Live Return" back.
Unfortunately, even though 240Vac is going out to the programmer, when the programmer is on I'm only getting 40Vac between the Live Return and Neutral.
I'm presuming this should be 240V correct?
Here's the wiring diagram on the back of the Potterton.
I've connected the Live and Neutral to the L and N (obviously).
I've linked out pins 2 and 5 (is correct or not)?
And I've wired the Live Return to pin 4.
Could someone just make sure this is correct for me.
Any thought on this would be most appreciated.
Cheers
John
Cheers
John
