Hi there
Living in a dormer bungalow, main bathroom is on ground floor with a mixer shower (has a pump which isnt working - flow is good without pump).
The upstairs bathroom has an broken 8kw electric shower which is supplied by a 6mm cable. I am loathed to put a new cable in if I can have a mixer shower upstairs too, with a reasonable flow.
The "airing cupboard" is next to the upstairs shower room - this contains a water tank and a HW cylinder. The header tank (water tank) would be at a similar level to the shower head.
I realise the flow would be poor - but is this where a negative head pump comes in? I did have an RGI in for a seperate issue and he took one look and said no, wouldn't work - but I can't see why not and didn't have time to discuss with him in detail.
The other question would be, is a 140l hot water cylinder big enough, i suspect not. I do not know the size of the water tank but can get dimensions if needed. I am considering upgrading this to a dual coil cylinder at some point.
Apologies for the rough drawing, but hopefully it sheds some light on my ramblings:
I had assumed a neg head pump somewhere along the bottom run would be needed?
House occupied by 2 adults and 1 female toddler and a baby girl. Am forward planning somewhat, considering that at some point it will be me and three females, so two decent showers would be good. Electric does of course provide backup etc. I did also consider a cheap 8kw replacement shower may be an incentive not to spend ages in the bathroom
Mike
Mike
