S
SaladFingers
If I put in the measured results BC would raise an eyebow wouldn't they?
Why?
For my LA (SLDC) there are different costs depending whether you do testing or not. For minor electrical works it's about £150 if you can provide test results, or about £225 if you can't. So it seems that whilst (I believe) they can't charge for testing, they simply have different charges depending on whether they need to or not.You don't actually need to do any testing for the BC. If the work is done under building regs they do the testing.
Why?
Then enter the Ze+R1+R2 figure.
Is the sum of two measurements a calculation or a measurement?
I consider a calculation to be the result of cable length and resistance per metre.
i.e. that done at design stage.
Someone who has learnt the importance of testing, and is using the correct route to notify/certify, I take my hat off to you sir![]()
I normally bypass the RCD for Zs testing now as my no trip Zs readings were not reliable.
Why?
Cos my Zs is higher than the the calculated (which must be due to the "no trip" function being untrustworthy I believe).
He should do them for himself though.You don't actually need to do any testing for the BC.
They can.(I believe) they can't charge for testing
For their prices they can do one.
What choice would you have? Break the law?
