Looking at a Grundfos SP3-50
(Single phase, 1.5Kw Max, 6A, 10Bar Max)
I can't for the life of me seem to find a decent controller to go with it for a reasonable price.
I'm looking for something like this:
http://www.italtecnica.com/index.php?ip=4&cat=1&prd=42
Basically it will be 8m down in a well, pumping up to a fairly "large" pressure vessel of around 150L, at 6-8 Bar, 4m above ground level in a loft, with a pressure reducer for the house's water supply at 2.5-3 bar.
I want a controller to be able to adjust that if the pressure in the tank falls below 3 bar it starts pumping back up and pressurising the vessel until it reaches 6-8 bar again, and stops pumping.
A mechanical on/off switch is all fine and well but there will also be a boiler in the same room running off gas, so unless its galvanically isolated i'd rather not go down that route.
Plus I believe you can't adjust them so well to say at which pressure they should come on or off.
The electronic version has other benefits such as being able to detect excessive current drawn (motor not turning) or very low current (No load on motor) as well as other nifty functions.
Can anyone point me to a decent controller that doesn't cost more than the darned pump itself? I'm looking at around £1-£250 for a controller.
A mechanical one can be had for £50,-
Cheers.
Cheers.
