My Dishwasher has stopped spraying water out of the sprayers. When I turn it on it seems to be starting up and the bottom fills with water.
But then that is as far as it goes, it still sounds like it is trying to run but the water does not spray out.
If I end the circle the water drains out normally.
There are no flashing lights for errors.
Any idea?
I thought it might be the pump but then would it drain the water out after? Are there two pumps?
Or the inlet valve? Would it let water into the bottom if this was faulty?
Read more: http://www.diynot.com/forums/plumbi...yers-not-spraying-water.327768/#ixzz1yBCMdBm4
Any idea?
