Further update. I gave the iso valves one more go last night so turned them both 1/4 turn and also shut down the iso valve on the incoming mains feed.
This time, the pressure held at 2 bar. I then opened the iso valve for the incoming feed and left it for a few hours, and the pressure stayed at 2.
So I guess I do have temperamental return/flow iso valves - either that or the BG engineer managed to fix them while capping off the boiler. Who knows - what I do know if that I have a leak somewhere. We ran a test today and drained the system until the pressure dropped from 2 to 1 bar (i.e. approx 1 day of pressure loss). Over 5 litres of water - I can't believe we can't hear it, it must be virtually gushing!
So we've got a heck of a lot of water leaking somewhere, so it's either ground floor over crawl space, or in a wall somewhere. I've just capped off the kitchen-diner, so will see what happens tomorrow.
Whitespirit66 - no pressure tester, but basically if after I've capped off the two different 'inaccessible' rooms on the ground floor and no joy, I'll probably get professional help.
