Pacific Flush Valve leaking
26 Feb 2010
West Midlands
Hi
I have an issue with my toilet where water is leaking into the toilet plan. I opened up the cistern and it has a Pacific flush valve similar to this picture
There are no external leaks between the pan and cistern and the water only starts to leak when the water level reaches the holes near the bottom of the flush valve assembly so the problem has something to do with the large rubber doughnut shaped ring that's attached to the blue part.
Anyone know where I can get a replacement rubber washer without having to replace the whole valve? If its not possible to get the rubber seal, which replacement flush valves can I get that are easy to fit without having to take the cistern off?
Thanks in advance
Rob
Try these:http://www.shop.lunns.net/flush-valves-nproducts14curpage-2-14-c.asp. They are obsolete now and aren't cheap!
£52 for a replacement? :shock:
Might as well replace the whole cistern with that amount! I guess I will have to replace the valve with a different type that is available. Do all flush valves come in standard sizes? Any ideas as to which flush valves can replace the Pacific type?
I have 2 of these buggers in a box - 2 brand new cartridges and 1 entire valve - any use? Mine failed at the cistern seal, so I had to strip the loo anyway and put a fluidmaster in instead.
The new parts I bought from Lunns..heh..so they're what you've looked at. As I say, unused and sat in my utility room.
Hi
Thanks in advance
Rob
Where did you get your replacement from and what did you buy ?? How much was it? Was it easy to fit?? thanks
Hi
Thanks in advance
Rob
I have 2 of these b*****r in a box - 2 brand new cartridges and 1 entire valve - any use? Mine failed at the cistern seal, so I had to strip the loo anyway and put a fluidmaster in instead.
Do you still have these parts? I would be very interested in one if you do.
