I have a number of symptoms
1) When trying to bleed rads, I struggle to get air out, but can hear flowing through the system
2) But when bleeding them, you would expect the expansion tank to replace the air with water but doesn't, just seems to allow more air in to system.
3)the water in the expansion tank also get warm/hot whilst overflowing at quite a rate.
Would I be right in thinking that there is a blockage in the system and what is the best solution (apart from a full system flush)? would part draining system and refilling with cleaner/sludge remover, running system, draining, refilling possibly repeating and then refilling with inhibitor work?
Any advice would be appreciated, Thanks Tim
