How to remove thecover from a worcester greenstar 28i junior
Status
Not open for further replies.
The front cover is actually the combustion chamber cover and as such should not be removed/replaced unless you are capable of performing safety checks afterwards.
Do you not have the MI's?
I just want to replace the MT10 TIMER programmer which you need to remove the cover for, just want to know how ?
I have got the MI - link was in my post earlier but section 2.1 doesnt mention which screws ? or does it slide off ?
As you have been told,the cover is part of the combustion chamber.No GSR on here will tell you how to remove it,you need to get a GSR heating engineer or plumber to do it.
Hey Phil,
Im not familiar with forums and even more boilers. Im experiencing the same issue. My timer is losing time and like you I can figure out how to open the dam clock. Im not paying £250 for a £40 part… I will keep researching and update this post.
A
The timer may well only cost £40.00 but the rest of the money quoted is to remove the front cover which is part of the combustion chamber.
Replace the clock replace the cover and carry out the legaly required safety checks. This is not a diy job if you do not replace the cover properly products of combustion can leak and are DEADLY.
Carbon monoxide is a silent killer, tasteless, odorless and colorless.
Please leave ro Gas Safe registered Engineer
Phil, the £250 will most likely be the fixed price to repair the boiler. The price remains same regardless of what is done by the Worcester man. It could be to replace an essentail crew costing £0.01 for 10 screws or a heat exchanger costing £999.99
My advice to you would be to get an installer to replace the internal clock for an exrternal one, better still get a programmable roomstat for enhanced boiler operation.
You have to think to yourself, if you do not have the sense or ability to work out how to remove the case EVEN WITH the instructions -
Should I be risking my health and that of my loved ones for £210.
Beggers belief, it really does :!: :twisted:
Worcester may want £250, but it doesn't mean that every RGI does :?
Op, you're missing the point - this isn't a decorative front but is part of a sealed unit that tends to withold potentially dangerous fumes from killing you.
Hey Phil,
A
You seem to have the same disregard of common sense and the regulations.
When you signed up to this site you agreed to follow the site rules!
Luckily if you did post advice to encourage a DIYer to do gas related work the site moderator will delete it for you.
In fairnesss though, they may well spend another 15 to 20 hours looking for the information they need which, at £10 per hour will supercede the cost of paying someone who both knew how to open it, make the repair, close it and test for leaks aftwerwards with the appropriate tools and equipment. What a bargain :roll:
+1 you would do well to get a good local RGI in to sort it for you may save some money.
DP has explained the WB call out charge very well, for your information.
Status
