How feasable is it to link the flow and return together and run the boiler without the radiators attached?
I have some work to do on the CH loop, adding a radiator, replumbing the tails on another and the like. As im only at the house weekdays I will be doing the work in the evenings after work so it may take several nights during which I need to be able to use the hotwater.
Obviously like most combis a loss of system presure shuts the boiler down, but if I add a pair of isolation valves just down stream, with a link between just boiler side, can anyone see anything wrong? As I would only be running the boiler in 'water only' mode I see no reason why they link shouldnt be 15mm, with an isolator for when the system is recommissioned?
Thoughts
Boiler is a Main 30HE fwiw.
Daniel
Thoughts
Daniel
