I need to know which terminals the cables are connected to in the boiler.
Turn power OFF
Remove lower boiler cover - it slides forward.
On the right you will see the junction box. Undo the screw and it hinges down and out.
One of the brown/blue/green-yellow cables will be the main power in to L and N terminals at one end of the terminal block. The other Br/Bl/G-Y cable will be the pump, to L and N terminals at the other end of the block.
The one I am interested in is the one on the right with red, blue and yellow wires. I need to know which terminals they connect to in the boiler. They are labelled: HW; CH; CH OFF and ON.
Turn power OFF
