Hi all got some issues with a glowworm swit flow 80 boiler. Rceently th fan was playing up causing the boiler to go out, after taking the fan apart and cleaning up it seems to be working fine, however since putting back togther things do not seem to be quite right, boiler lights and stays alight, main burners come on when C/H is wstiched on or turn hot tap on. However hot water is now only luke warm and the main burner instead of being the a nice blue flame now looks like the fires of hell itself (bright yellow).
Is it possible that I have put the fan back togther wrong (bear in mind I did not disconnect the electrical terminals, just used the main off switch). I intend to get it serviced properley but in the meantime is there anything else I can do.
