I rent out an old property which is empty at the moment and the cylinder/tank had a crack so I got it changed...
a few days later i had to drain system to change a TRV and then noticed the system wasnt refilling... the plumber didnt know why... he assumed it was a normal tank so has replaced like for like. I asked around/researched and it must have been an old primatic tank. He admitted his error.
As i write this; the plumber is putting in a F&E tank in the loft.
My concern is that reading on here and other websites it says that when replacing a primatic tank it should be replaced with a indirect cylinder tank?If as ive said before the inexperienced plumber has put in a 'normal' tank, will i get hot water at all out of my taps or is he gonna have to swap the tanks again?!
much appreciated
much appreciated
