hi..my 12 year old ideal ff260 wouldn't start tonight...fan not running.... i changed the fan a couple of years ago.
did the usual checks as per the flowchart, no volts at fan molex, and the fan relay is really blackened and when i removed the pcb i noticed that the solder on one of the relay pins and track was missing.
re soldered the pin and all is now working ok.
so just in case it fails again i have ordered a new relay from RS ready to solder in if needed.
if all else fails i've done some searching for a new pcb and the prices vary massively, also pcb 25b's are few and far between....... my question is............
is the later versions PCB25 E , compatible with the PCB 25B (part number 079716...... 386 149)
the PCB25E is more readily available on ebay etc and cheaper.....
thanks...H.
thanks...H.
