Best advice is to call some local electricians, ideally some that have be recommended by family/friends. The work will require notification, so building control application of self cert electrician will be needed.
You are going to end up with something nearing 90A on full load, so a tasty sized cable will be required and a unit with a 100A isolator.
It is more than likely the cable will need to be buried about 2 foot underground, unless the cable can be fixed to a secure structure along its route, this would normally be a wall rather than fencing, also could be put on a catenary overhead cable, this would require a height of around 3.5m.
Prices of installation vary region to region, as do notification fees. So to put a price on it, bearing in mind I don't live in your location and have not seen the work required first hand would be impossible, as lots of variation are to be considered depending on the existing set up you have.
