Morning all,
I have recently moved into my first house and have been having problems with my central heating. My current oil setup is a floor standing boiler in an outside building and a cold tank in the loft and a hot water tank and red pressure tank in the cupboard. From what i can tell i have two pipes go from the outbuilding to the loft then goes off to the tank cupboard. When i moved in i noticed that the pressure gauge on the red vessel was reading 0 so i tryed to use the external fill tap to add pressure but it didnt work. After replacing a blocked pressure "grey" valve i then filled the heating system back up and bled all my radiators. When the heating is on they are lovely and hot all over but this is where my problem starts. Now and again i get a loud noise from the boiler/pump which sound like the pump is loosing water and is trying to move air and you hear bubbles in the pipes now and again.
How can i drain this air in the system as when i bleed the rads all i get is pressured water no air... therefore i think the air is in the loft part.
Thanks in advance any help will be greatful.
Oh i also had the system running for a hour a day for around a week before i noticed the red vessel had no pressure.
