There's a lot written on this! I have a top floor bedroom with a roof above it that is in two sections - one side is pitched with felt and tiles, the other is 'flat' with boards and felt. The tiled side appears to be ventilated, the 'flat' side is unventilated and cannot be ventilated.
I have removed the layer of plasterboard beneath the joists. I will replace this but am contemplating heat insulation.
Already I can see droplets of condensation on the bottom of the felt in the tiny gaps between the boards.
There is no insulation between the boards and the felt.
I am on a low budget with this one.
What is the best economical solution?
I am considering just putting 2 layers of plasterboard back up to marginally improve the insulation as I am concerned about the condensation issues with an insulation layer. Maybe do insulation at a later stage if and when I replace the 'flat' roof from above?
Please advise, bearing in mind the low budget!!
