This problem has been bothering me for some time now, I would very much appreciate any ideas people might have,
The system is a Worcester Greenstar 24i Condensing Gas Boiler (3 years old) controlling the Central Heating (sealed – top it up using a filling loop) and Hot Water (open vented, large insulted copper tank and water tank in loft which tops it up).
The air accumulates in two of the upstairs radiators (at the highest points) and the magnetic cleaner. Today I bled a total of a ¼ of a radiator full of air from the three points after the heating had been on for two days. The pressure gauge returns to 1 bar but after two or three days of use, its back up to 1.5 bar (cold) and a rebleeding is necessary.
The radiators themselves are old, 20 – 25 years (all copper pipe, no plastic push fittings). When the new boiler was fitted a power flush was performed, inhibitor added (prior to us owning the property) but I have no reason to doubt this.
First I emptied the system, water was discoloured (yellow-green) but only slightly. Topped up again and 4 litres of good quality inhibitor added (only requires 1 to 1.5 litres) but better too much than too little. Didn’t help even after several months of running the system. I also disconnected the filling loop just in case but this didn’t help either.
The helpful plumber suggested turning the pump from position 3 to position 2 (3 being the highest pumping rate, 1 being the lowest) and also adding 1 litre of leak sealant. This didn’t help either.
I cannot believe that in the knowledge the system was flushed and now has 3 times as much inhibitor as required that this is due to hydrogen gas (corrosion). The plumber seemed to think the air was being sucked into the system and I thinking due to the quantity of air bled, this is likely the case.
The boiler is annually serviced (as still under warranty) and seems to be working fine.
My expertise ends here, any suggestions would be most welcome.
If additional information would be helpful and/or photos please say.
My thanks in advance !
