Recently our consumer unit, a Memera 2000, has tripped several times. All instances so far have been when we were out or at night. In all cases most items are off with only TV and PVR on standby. Combi boiler central heating is off, waher drier too. That only leaves the fridge and frezzer active.
Our house was built in 1971 and we moved in mid 2002, and found the previous owner had been a should not have done it himself man. To correct his misdemeanours we had an electrician in.
ate 2002 we had the kitchen and utilty room refitted, at which time the old fuse box was replaced with the CU by a qualified electrician.
Sorry about the image quality, The items covered by the brown switches left to right
Garage and front door sockets
Utilty room, boiler, fridge
Sockets
Cooker
WC fan heater
Downstairs lights
Upstairs lights
I am not a DIY man amd will be calling in a qualified electrician. However I would like your thoughts on what the cause of the trips might be, and what might be a way I could have some idea the fault lies, also anything non leccy I could look at in likely faulty equipment,
Over to you!
Sockets
Cooker
WC fan heater
Downstairs lights
Upstairs lights
Over to you!
