Hello Everyone,This is my first post so any help would be appreciated. I have an Ideal Classic RS 260 wall hung balanced flue gas boiler.It
has Two, Two Port Diverter Valves and is wired with a Lifestyle Heating Control Pack. The boiler is in my garage and also has a stat at the side of the bolier. I assume this is a frost stat.For the last 6 months the Pump sometimes carries on running when the water and heating is off.both valves closed .Also when the Programmer Central Heating button is off the Heating stays on if the Wall Stat calls for it. So basically i turn the heating on and off with the room wall stat. I have fitted two new diverter valves as i was told the micro-switches were sticking but this has not done anything.The Hot Water seems to work ok ie with Programmer as it should and cylinder stat works ok. I have been told i need to replace the Pump Overrun stat but can find no mention of it when looking at the Parts Manual. Can anyone help please.
