small leak from boiler
29 Apr 2012
London
hi
today i noticed a small leak from the pipe going to boiler.
have uplaoded photos on the album.
http://www.diynot.com/network/xyz321/albums/15434
Can someone please tell me:
1) likely cost of fixing this?
2) does entire boiler has to be removed to fix the problem?
3) do i need to very urgently fix this or is it ok while plumber gets around to coming in couple of days?
ta
Hard to tell from so close in but looks like a flow or return pipe leak. It'll wait, easily fixed in 30 minutes but you'll probably be charged for an hour to cover the callout
thanks. i can see some "green" stuff gathering around the pipe connection where the leak appears to be. is this anti freeze? if so, it is relatively easy to replace or am i looking at an expensive repair.
the boiler is a conventional boiler from bosch and is about 3 years old.
