Painting disaster
9 Mar 2013
Staffordshire
I recently painted the door and skirting in my bathroom and few weeks down the line the stain from the stain which was already in the door is seeping through. I now know I should have used primer first not undercoat. Now I have a patchy white door. Do I sand it down and use a primer and normal bathroom gloss? If so what type of primer is best?
The stain could be a knot in the wood and the resin is seeping into the surrounding paint.
Unless the skirting and door was bare wood be reassured there was no need to use a primer. Undercoat is sufficient. If the door is patchy it's probably that there was quite a drastic change of colour and one coat wasn't enough.
Lightly sand down the woodwork and then give it another top coat.
are there any pics of what it looks like?:cool:
just joined this site don,t really know what I,m doing but when painting most types of wood if there are any knots in the wood they should be treated with a knotting solution it dries in about 20 minutes then rub down the treated area with some sandpaper then use primer I always put 2 coats of undercoat on and your final finish will be better don't forget to give each coat of paint a light rub down.
Haha we've all done all the above mistakes i dont even wanna start but i have learnt my lessons now anyway
