Conservatory Roof U-Values again.
20 Mar 2013
Essex
We're looking to build a glass roofed extension/conservatory on the back of our house (7-8 metres long).
We want to use this room in winter and so are keen to make the roof and windows as warm as possible (without going for a solid roof).
We are considering a glass roof from PolySolar which has integrated PV and is reportedly affordable (waiting on final quote, but it is a different type of PV to normal and is cheaper although less efficient - 8% instead of normal 15-17% but much higher Watts/p).
The U-Value for this is quoted as 1.4, whereas a solid roof would be 0.2.
This thread suggests that 1.1 - 1.2 would be an acheivable value, but that once we're under 1.4, the bigger savings can be harnessed from better frames.
http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=3304
Is anyone aware of, or seen any "Secondary Triple Glazing" that could be applied in this case ? I'm thinking that I'm not worried about my head room, and single skin of Acrylic or Glass below the conservatory roof (but not in contact) should perhaps help this system approach a U-Value more like the Ultrafram Utopia (see my other thread).
(by secondary triple glaing I mean just a separate piece of glass or plastic inside, like what people used to use to convert old glass to double glazed - apparently the U-Values weren't so different to a sealed unit in the early days).
Not sure if that makes sense.
I've correct my post - thanks.
I don't imagine I'd be able to approach 0.2, but perhaps closer to the 0.6 that the Utopia Roof system advertises (which would be twice as good as the 1.4 being proposed - half as much heat loss through the roof)
