Hi All,
I had a neighbor remove a chimney stack with my permission, however their builders did not do a particular good job. I have had a survey conducted and this was the feedback
• The concrete interlocking tiles have not been correctly cut and installed properly, they are dislodged and not fitted to the battens beneath.
• The soil slate cover should have welted sides and tiled over instead of being laid on top.the rubber should also be siliconed.
• The leadwork has been reinstated poorly and needs to be redressed correctly.
• No render stopbead has been fitted to match the existing above the lead flashing and the rendering is again poorly carried out.
• The coping stones have huge gaps and have not been cemented back to their original positions.
• Inside the loft, the soil pipe flue used has a batten wedged inside the pipe clip.
• The existing brickwork has not been taken down level, motar debris has been left and the insulation has not been relaid, and there is a visible hole through to next doors conversion.
I just had some further questions.
Where the chimney was removed, the flue from the chimney stack has been left partially exposed in the loft. Is this going to be a problem, and should it be completely bricked up from up to the roof structure. (please see flue setting in loft picture). Just wanted some advice on this.
Please see my pic album http://www.diynot.com/network/krystar/albums/
for pictures of what i mean
Thanks in advance
Thanks in advance
