I am replacing a brass pendant light fitting with a plastic rose and pendant. This is in a downstairs hallway, operated by a two way switch which also switches the upstairs landing light. I've been trying to get a good look at the existing downstairs fitting and can make out the following
1. a red cable connected to L
2. a black cable connected to N
3. a cable in earth sleeving connected to Loop
4. also from Loop a cable in earth sleeving going to a terminal on the light fitting itself
5. also from Loop the earth cable which leads down to the lampholder
How should I connect up the new fitting? 1 and 2 seem straightforward enough (red to L, black to N), and presumably I don't need to worry about 4 and 5 since the new fitting is plastic rather than brass (but please let me know if this is wrong). What I suppose I am really wondering about is the cable in 3, why that is connected to Loop, and whether I should do the same on the new fitting or connect it to the earth terminal?
thanks in advance
thanks in advance
