Hi guys
Need to replace our existing driveway as block paving has badly sunk. Its an old drive.
Had the following quote for an imprinted concrete drive. The area is flat and around 46 sq. metres
Excavate proposed area and lay clean MOT type 1 aggregate and compact to within 5% CBR limits.
Dismantling and re-build of brick column as agreed to widen driveway.
Install drainage (either deco or aco) where required around the foot print of property and connect to soak-away drain.
Install new manhole and drainage covers where required.
Install 1no step (either semi-circle or square).
Installation of ‘Buffer Lip’ to entrance.
Install pattern imprinted concrete (colours & patterns to be confirmed at a later stage) to the specified measurements; minimum 4 inch depth.
The option to have a circle feature if desired, which is included in price.
Install a ‘PICS’ acrylic seal with ‘Rhino Grip’ anti-slip agent.
Inclusive of materials, labour and disposal.
Our price to install pattern imprinted concrete to the agreed specifications and dimensions would be £3,350.00 The prices given above also includes for a 10 year guarantee
Anything sound wrong? Old drive photo attached
James
James
