Hello,
I had to tidy up some wiring on my S-plan system yesterday - the boiler has an overrun and we use a megaflo 120 for hot water. The wiring for the pump overrun is done so that the pump runs with the only circuit being the closed loop with bypass (automatic bypass fitted at 0.3bar) - both the heating and hot water valves are shut during this phase. This all works fine.
I was wondering though whether anyone thought it might be a good idea to write a simple logic board so that the CH zone valve would open during this phase so that the overrun circuit would include the rads. This would surely make the overrun duration shorter, and it would use the heat in the closed loop.
It needs a logic board as clearly you can't just use the overrun signal to open the valve or it will switch the boiler on again.
I think that's how it is on a Y-plan but not totally sure. I'm not sure it's worth it and whether it would benefit the boiler or not. Any expert opinions gratefully received!
