Hi
Ive just had my new extensions roof tiled 1 week ago.
Its a lean to roof consisting of 6x2 C16 rafters at 450 centres fixed to a 6x2 bearer. The span is around 3m on the floor or 3.3m measuring taking the pitch into account (the span tables suggest 6x2 is OK upto around 3.6m clear span.) Ive added noggings accross the middle to prevent any twist.
Ive noticed that the rafters have settled so when you put a straight timber across the length of the rafters there is a 8-10mm gap at one end.
Its very slight, not noticable to the eye so do you think this is normal/acceptable or do you think I need to look at at installing a purlin or further support? Id rather not due to the aesthetics but obvioulsy I want it to be sound.
What Ive installed appears more then sufficient and building contol havent had any issues but I just want to make sure its done right before we install the insulation and plaster board it.
Thanks for looking
Thanks for looking
