- Joined
- 6 Oct 2010
- Messages
- 126
- Reaction score
- 4
- Country
Hi all,
Our shower's on/off button has stopped working all together. No shower at all.
My OH likes to fix things himself and removed the casing for the existing Mira Sport shower, after turning off water and isolating electrics to shower and it says it is a 9kw 240v Mira Sport model.
He removed the shower after speaking with his father (a retired engineer and self professed DIY'er) and thought it was a straight case of nipping to a local shed and buying a new shower and installing.
I've checked this out though as I'm the researcher and I think we may have to have a sparky, even though we are totally skint and buying the shower was bad enough.
So Facts:
The Mira Sport shower was already installed when we moved in 6 years ago and is 9KW at 240V.
We had a modern RCD Consumer Unit installed in 2007 when we moved in.
On the RCD, the Shower has it's own switch stating B32 for 230 volts, the Cooker meanwhile says B40 (I assume this is the ampage). The Downstairs/upstairs sockets are on a B32 as well, while the lights say B6.
The Shower has it's own isolation switch inside the boiler cupboard (red flippy switch), as well as its switch on the RCD fuse box.
The cable running from the RCD to shower can't be more than 10 metres, as the bathroom sits 1 room from under the stairs in a small terrace.
The electric cable feeding the shower is routed under plaster with roughly 4 inch's neatly sticking out and looks in good condition BUT it is Red, Black and Earth, with the first two having 7 wires but the earth just being the 1 wire.
I have been struggling to decide as to whether this cable is 6mm or 10mm but I suspect 6mm, as just went to Bonus Electrical and looked at 10mm cable and that has 7 wires in the earth as well + looks very slightly bigger overall + obviously is blue and brown newer cabling inside.
So... questions...
If we only have red, black, earth - 6mm cabling, and that has been feeding a 9KW shower for 6 years quite happily, which our electrician must have checked somehow, as he installed a 32 amp fuse in the new RCD for it, and considering the old fuse box was the old, single copper wire system, which was wired previously to the same shower (surely bodgy!?), then can't we just install a new 8.5kw shower ourselves?
Only thing is, I checked the online manual for the Mira 8.5kw showers such as the Go and Vie, and they say they need a 40amp fuse in place and state you can use a max of 10mm wire for it, but not that you must use 10 mm.
Now my OH says he can just replace the fuse in the RCD with a 40amp and that is not hard, but I thought, does the cable have to be 10mm for a 40amp fuse or it will melt?
Also if we retain the current cabling and do a straight swap to a new 8.5kw shower and either leave fuse as 32amp or change to 40 amp, do we need to notify building regs?
Lastly, what sort of quote do you think we'd be looking at for replacing 10metres of 6mm cable for 10mm and checking fuse + labour for a sparky in Yorkshire area and would it involve ripping out tiles and pulling up floorboards etc?
Sorry for length of this but like to be thorough!
So Facts:
So... questions...
