Extending outdoor socket to another
18 Jul 2013
Hi all
I'd like some advice on extending from a curent outdoor socket to add another one elsewhere on the house.
Is this a fairly easy thing to do?
Not taken the socket off to see how its wired, thought i'd ask a little advice first.
Had a quote from an electirician but quoted me £150 per meter for armoured cable as i originally wanted it to run along side the house in the ground...seemed a crazy price to me for cable!!
Might just do it myself with conduit along the wall.
Thanks very much guys
Daz
Is there not another internal socket that you could spur through the wall from near to the required location ?
There has clearly been an error or misunderstanding there! If this figure related just to the cost of the cable, then I suspect he may well have meant £1.50 per metre for the armoured cable - I suggest you ask him for clarification!
that was what I was thinking, but there's no way you could justify £750 for a 5m run of SWA.
FWIW I just joined my two outdoor sockets with a short length of conduit - its only about 15cm but it does the job nicely.
Good advice.
This may prevent a lot of work and unsightly wiring.
The existing outdoor socket may well already be a spur - as outside sockets very often are extras that have been added. So you need to look at this.
I prefer not to use plastic 20 mm conduit outside as it sags, gets brittle, gets broken, and has to be watertight - unless it's erected in a manner where water cannot enter the sockets.
Ricicle's idea may be the answer.
