I am new to this forum, but have found some brilliant advise on here before so thought it was time to sign up and join in.
Basically my F&E tank in my loft overflows during the night, from about 12 - 6. (Wen all the hot water and heating is off.) The water seems like it could be coming out the vent pipe as its warm.
Im not sure if its a bit of both with the ball valve getting stuck as it is an old tank but it does seem to shut off eventually when i empty the tank out.
I have tried turning the heating off and draining some water out of the radiator drain off to see if there is a blockage in the feed but it flows through the F&E fine.
I have also checked to see if the pump is running on and is then over pumping at night, but that cuts out.
Im slowly running out of ideas, i just can't work out why it would overflow when the system is off over night.
Any help would be FANTASTIC!!!! Thanks
