I'm not really sure what that would achieve. If the cable is adequate (and given that the current taken by whole lot is limited by the fuse in the first one), then I can't see that it really matters whether high loads are plugged into the first or third one, does it? In general, of course, 'daisy chaining' extension leads is even less 'ideal' than using one!If it should become necessary to daisy-chain trailing sockets, then a method of control would be to down-fuse the second socket strip to 10A or 7A, and, (assuming there is a third!) the third to 5A or 3A. This would help act as a control on loading.
I suppose that makes sense, although I suspect that the copper conductors within a (decent) extension (between socket outlets) may well have a higher CSA than does the flexible cable.Please also bear in mind that the socket to be used for daisy chaining is that closest to the cable inlet. This helps avoid high(er) loads having to travel all along the copper inside the trailing sockets.
