Extension lead length
J
jonathen
Hi all,
I currently have my PC and a load of other peripherals plugged into a 6-gang 2-metre surge protector extension lead. There are not enough sockets so I have to switch between devices which is a pain. Unfortunately it does not quite reach the mains socket, so it is daisy-chained into another, shorter extension lead.
I am under the impression this is not safe practice - first of all, why is this not safe practise? What threat does it pose?
Secondly, I want to remove the threat so I need a 3 or 4 metre extension cable that is 8 or 10-gang, and preferably surge protected. But do you think I can find one? Not for love nor money! I have been to every electrical and DIY store and have scoured the Internet but cannot find one.
I can get 8/10-gang extensions that are 1 or 2 metre. I can get 3/4/5 metre extensions that are only 2 or 4 gang. But no 3/4/5 metre 8/10-gang.
Is there a reason these are not available? Like some kind of safety issue? Or is it just supply/demand? Does anyone know if there is this type of config available?
Thanks in advance for any advice.
Jon
J
jonathen
Well, the plugs are required for:
monitor
pc #1
pc #2
belkin kvm
speakers
printer
cable-modem
digital camera
side-light
You see, it's in part of the room that has no wall sockets at all and is about 3 metres from the nearest wall sockets.
31 Mar 2006
Leeds
Diyisfun said:
Thats a lot of periferals, are they all PC related?
No, this is a lot of peripherals
:eek: :eek:
17 Nov 2006
West Glamorgan
It's not instantly unsafe, as computer peripherals do not consume that much electricity and you are probably well within the limits of the leads. The reason it's deemed bad practice though is that some people with only 1 socket in a room will daisy chain them together and plug in a lot of items including some high power appliances (heaters for example). This will overload the 13A fuse in the plug it will blow. After one or two times people get sick of replacing the fuse and it has been known for people to put a nail/pipe etc. in the fuse carrier to stop it blowing. This is very dangerous and can lead to fires.
My attitude is that if you need to daisy chain extension leads together you should just get a permanent socket fitted. But I appreciate not everyone wants the hassle/expense. You are allowed to extend your circuit if you feel confident and this might be a cheaper solution than the extension leads.
Davy
B
breezer
Davy
no it isnt, not by a long chalk.
trouble is with a pc you can have, monitor, speakers, scanner, subwoofer, powered usb hub, pc tower, charger for mose (cordless) charger for keybopard (cordless)router, external hard drive, external zip disc etc etc, so that is why people daisy chain 4 way blocks together
all of which only draw a few hundred miliamp each at most, so nowhere near 13A
oh forgot to mention surge proteced 4 /6 way block
2 Jun 2005
Cumbria
The reason I understand cascading extension leads is frowned upon is you can end up with a very long lead of small CSA which may not disconnect quickly enough in a fault. Not such a problem with short leads.
B
breezer
Oh i forgot, digital camera, other pc tower, scanner,monitor,speakers external hard drive, printers etc
I would suggest that you only daist chain when you really must
plug one 4 way blcok in, then other 4 way blocks ito this.
that will give you 16 sockets that should be enough
17 Nov 2006
West Glamorgan
breezer said:
Davy
A 4 metre 8 gang surge protected extension lead (if they are even manufactured) will unlikely be cheaper than a double socket and 2 metres of twin and earth.
For comparisons sake (TLC):
£8.40 - 6 Way Anti Surge Extension Socket c/w 2m Lead (not suitable but the best they offer)
£8.32 - 2m twin and earth + double socket + back box + delivery
He's already got the short extension leads so he wouldn't need anything else.
31 Mar 2006
Leeds
I'd rather folk used plug in leads, rather than trying to wire in 4 twin sockets them selves.
pre made leads are safe enough. 4 spurs from one socket, installed by someone who doesn't know what they are doing is not safe.
B
breezer
no comparison, mine is still cheaper
too many + in that
assuming you do mean that is the whole lot though.
£8.32 - double socket
your way saves a whole 8p (whoopie)
my way you get 6 sockets (with anti surge)
your way only 2 sockets with no anti surge
not rocket science is it.
17 Nov 2006
West Glamorgan
I'm not saying he should wire in enough sockets for everything, I just meant he could wire a spur a bit closer so he doesn't need to daisy chain the leads.
And how do we know he doesn't know what he's doing? I know there are some idiots out there but its not fair to assume everyone is unable to wire a socket safely when given suitable guidance.
Davy
B
breezer
so whats the point of yours then?
person in your scenario,
has to find help (ok we know about diynot, not everyone does) go and get right kit wire it in and still only get 2 sockets
my scenario
buy surge protected 4-6 or 10 way block plug it in
no, i don't want to argue over this, its not worth it, and no point in upsetting anyone, its just a fact of life that my way is eaier, fullproof and what joe public will do
17 Nov 2006
West Glamorgan
my scenario
I'm certainly not arguing, your just making comments to make my advice seem totally ridiculous.
The original poster didn't want the leads daisy chained - your solution is what he's got now. My solution is a possible option with little extra cost.
I totally agree that your solution is easier, perfectly safe (for his needs) and what most people would do. That doesn't mean it's the only solution worth considering.
