- Joined
- 12 Jan 2006
- Messages
- 77
- Reaction score
- 1
- Country
After many years of unreliable service I have replaced Potterton Puma 80 with Worcester 24 i. This replacement work was performed by British Gas.
Radiators are still original but system was cleaned , inhibitor was added.
Worcester was operating fine until this week when heating was turned on for the first time after summer. The result was some noise and after few minutes boiler stoped. I checked and pressure was low, I have then filled system with more water but the problem does not go away.
When turned on, boiler seems to run start up sequence. Ingition light comes on for short time. All this time noises are comming from boiler that sound as if plenty of air bubbles are released or developed. After short time boiler stops and red light comes on. Reset button does not resolve the problem.
Even if CH is turned off and only DHW mode selected same problem appears.
I suspect some form of air lock or blockage ? Any ideas and how to diagnose this ?
