Complete new house wiring with 2 showers
You shouldn't be allowed anywhere near electricity with questions like that... You'll end up frying yourself if you try doing any of the work yourself. Leave it to the professionals please!
I would suspect that one or other of those things has probably already happened in the 18 months since the discussion took place!
I am not doing this myself just learning a few pointers..
Well you need to read this first.
http://electrical.theiet.org/books/regulations/17th-edition-amd1.cfm
One more question, Lets say there are number of wires in the lighting circuit where you have wall lights and centre lights, is there a tester that would help the distinguish which wire goes where???
Yes there is but it won't help unless you understand how to test and how to interpret test results. You need to read this first.
http://www.waterstones.com/waterstonesweb/products/jon+elliot/guidance+note+3/6276119/
Once I saw a guy with a tester, with all the electrics off he was able to find out which wire from the switch went to the centre light and which went to the lights on the wall. What do you call that tester...
Read the above Guidance book and all will be revealed.
PMSL!! I have had to read both those books and have the 17th edition and 2391 inspection and testing qualifications... which allows me to install consumer units. Nobody should be allowed near one without at least those quals!
They might do - we do see people here with those but still without a clue.
Or sufficient competence.
