My troublesome 4 year old Vaillant EcoTec 831 has now developed another problem that has me stumped.
The boiler stays firing in CH mode even when the thermostat isn't calling for heat, resulting in things getting a bit warm in the house. These are the things checked so far:
1. Thermostat checked, contacts definitely open when not calling for heat.
2. 3/4 disconnected on boiler to ensure that boiler wasn't seeing an accidental wring fault in the wired thermostat connection, boiler still runs in CH mode as if being called.
3. First diagnostic mode indicates that thermostat isn't calling for heat (indicates 0 in diagnostic selection d.8 )
4. Resetting boiler has no effect, radiator symbol remains on when boiler restarts and boiler fires, even with no call for heat.
Boiler can be "fixed" by turning the power off for at least ten minutes, ten turning the power back on, when the boiler will return to normal operation. However, after an hour or two it will get "stuck" again, with the CH always on.
DHW works fine, the only error codes logged are all the old F.75s that were before the "F.75 repair kit" was fitted (at significant cost). Pressure is normal (half way up the grey band), the diverter valve (also replaced within the last year following another failure) looks to be working fine, the system has a Magnatec fitted in the return (and that looks clean inside).
I suspect this latest fault may be within the PCB, as I can't see how the display can show that there's no call for heat from 3/4 yet the boiler is still happily firing in CH mode. When it is firing with no call for heat the only ways to stop it are to either turn the CH temperature knob fully ACW or to turn the boiler off.
Before I lash out on a new PCB I'd find it really useful if anyone here could see if there's something I've missed in trying to pin down the cause of this latest problem.
