Trianco Boiler - Hot water issue
24 Sep 2004
Good evening,
We have a Trianco Eurostar 90 combi, installed in 2005. We have been putting up with an issue that nobody can seem to get to the bottom of, not even Trianco themselves.
When the hot water thermostat dial on the front is turned up to its maximum level the boiler comes on and produces hot water. It then comes on periodically to maintain the water temperature. When a hot tap is opened, very hot water takes just a few seconds to come through. All seems well, however, after a maximum of 10 mins the hot water runs out completely and the water is barely luke warm. The boiler is running, but it doesn't seem to be able to produce hot water quick enough to cope with demand.
Even if the temperature level is turned down to a lower level, this problem remains. This problem has persisted since we bought the house a couple of years ago and nobody seems to have an answer. When running a bath, the hot water does not fill 1/3 before running out.
Any ideas? When running the heating, the boiler seems to work perfectly.
Thanks for the help.
This should be easy enough to sort out.
1. Is the heat store fully hot. This can be checked with a temperature probe.
2. If the burner is firing is the heat going to the heat store? Again easy enough to check.
To sort out. I would suggest disconnect the plate heat exchanger and heat exchanger, and heat store connections.
Thoroughly flush with mains cold hosepipe etc. Ensure all hoses are also clear.
Put back together. Should be fine.
Don't know if this boiler has a blending valve could just be the blending valve is faulty. Again easy to check.
That's very helpful, thanks. I will get that done and keep my fingers crossed.
