We are having a complete new heating system installed: 31Kw Vaillant EcoTech, seven rads and new pipes. My first though was to replace the existing 1970s microbore with 15 mm copper lagged with Tubolit or similar product.
The first couple of engineers wanted to use plastic pipe, but it is the ground floor of an 1890s tenement building and there are rodents present, which put me off this idea.
The only guy willing to do copper wanted to use 10mm coated copper, which to my mind is borderline microbore. He claims that the coating serves as an insulator, but I don't believe it. If it was an insulator the manufacturer would have a thermal conductivity value. The wind blows freely under the floor and insulation is therefore important.
I would like to ask the forum about whether it is worth going to the extra expense of installing 15 mm lagged copper pipe. My first though is, yes, because those pipes will be radiating heat under the floor for the next 30 years. However, I might be living in the past, so I am asking which pipe:
plastic, unlagged 10 mm coated copper or 15 mm with lagging? Or I suppose we could lag the 10mm as well.
Thanks for your advice.
