Again hope you guys dont mind me putting these up, some of you may find a modicum of intrest in them, and some may have seen these things many times over.
Changing the insulating oil in a 60 plus year old 33,000V Circuit Breaker rated @ 400A and a short time rating for 3 secs of 13000A.....
The oil tank is lowered from the actual breaker, on the R and L (hidden) of the pic, are the RING SWITCHES (manualy opened & closed only)
33kv Male contacts roughly 40mm diameter....
The female contacts are hidden in the ARC extinguishing pots (we didnt take them off)
When bolted up, meggared and ductered, the circuit breaker can be manually RACKED in horizontally into the CIRCUIT and BUSBAR bushings, then closed in a pre-historic fashion of manually charging springs and pushing a mechanical button with a clatter and bang that hurts your ears (mechanical clatter and bang!!)
There are still loads of these historic Ring Main Units on the system, and still giving sterling service,
below is its modern day equivalent not a drop of insulating oil and a breaking gap of about 2.5mm!! and all controlled remoteley from a warm air-conditioned office via a PC....not sure if this stuff will see service for 60 years though!!!! (apologies for rough pic)
