We have a Daikin Altherma HT heat pump system which drives one zone of underfloor heating and 2 zones of rads (upstairs and downstairs). This Daikin system has inverter driven pumps and compressors so can adapt somewhat to load and has weather compensation fitted and working.
The u/f works really well with the Continental room stat.
The rads are controlled via Honeywell CM901 room stats. I've read and mostly understood the other posts on this site that describe the TPI control system that the Honeywell stats use.
However, I'm wondering if these Honeywell stats are appropriate for heat pumps. The issue is that when the stat is in the PI zone, the minimum cycle frequency and minimum cycle times just don't seem to be appropriate. Our heat pump has a 10 min start up period and then takes at least 30 mins to get the flow temp up to anything sensible (say 50C) even at this time if year. In colder weather it can easily take more than an hour. We find that the stats come on and off regularly night and day without the rads heating up at all. i appreciate that the CM901 is supposed to be a learning system, but that's not how it appears to behave in practice.
And before anyone comments that heat pumps should be run continuously, could I say that I understand that but in early winter/ early spring, the heat demand is not sufficient (the heat pump can't modulate low enough) and the electricity consumption goes through the roof (not literally).
Should we be using a room stat where we can turn off the TPI, such as the Danfoss TP7000 series so that the heat pump will come on less and run longer even if that means somewhat wider fluctuations in temperature?
Any thoughts?
Any thoughts?
