Think my pumps poorly - can you confirm??
jackthom: Well spotted! - the pump body doesn't seem to overheat now. So: I've just switched the elec off, disconnected the wiring @pump and put an ohm meter across live and neutral. Result= 100ohm resistance. So, assuming I'm measuring the right thing, not open circuit right now. BUT, does the capacitor also bridge live/neutral? - could I be testing its resistance rather than the, possibly opencircuit, electromagnet wiring?
Andy: I've hesitated over that. Previously when I've replaced components in old plumbing, I've ended up replacing a lot more than intended as standards have changed, new things don't fit, aren't really compatible etc. As far as I can see "Grundfos Multihead type G p/n 59506180" pumps aren't available any more...
100Ω is too high and no the cap doesn't bridge live and neutral on its own it is in series with another winding. you will only measure "resistance" across the cap while it is charging anyway, your pump is kaput fit a new one
Matt
Matt, Thanks! Sounds definitive.
Ref my response to Andy above : "As far as I can see "Grundfos Multihead type G p/n 59506180" pumps aren't available any more...". Which pump do you think I should use as (an exact fit) replacement?
Should I be checking anything else eg the electronics control box, after a pump burnout like this?
I haven't got the specs to hand but most likely an alpha2
but you may still be able to get a hold of a ups 15/60 , wilo gold rs60] or other equivalent from somewhere if your lucky
you will have to change the whole body not just the head though
Matt
Matt, Your mail crossed with me ordering this http://preview.tinyurl.com/mrxvd25 , which I'm assured by Mr Parker of Parker Pumps Ltd will fit, has 5y Warranty, and be here asap.. The wilo looks a quality product.. perhaps I should have waited. Thanks anyway.
Have bunged everybody who helped a Thanks (incl Mr Tony "RTFM" Agile). This is a good Board.
