The insert for the waste trap on my shower is missing causing a bad smell when en suite used. Had drains contractor come out due to smell thinking it was the drains but he then pointed out the missing trap. He wanted £95 to replace the insert, not the whole trap just the insert that goes in there.
No call out charge, the insert he said was £11 and he said it would not take long at all so am thinking £95 is abit alot.
I have looked up prices for these inserts and they range from £2 to £11 but i am just wondering how you measure it to order the correct size. Diameter of unit in tray now is 40mm and 60mm depth then has 5mm of so of air then a further 30mm of water until you hit trap bottom, any adive of what size and were to order would be appriciated.
thanks.
thanks.
