Worcester 28Si II Red light flashing
27 Nov 2013
Cheshire
Hi, I have the above boiler and over the last week or two the red light has started to flash. Sometimes fast, sometimes slow. I have read the manual but it only provides limited information and no suggestions for long term remedy. Resetting does work sometimes but the problem returns. The boiler has also started to make what I would call 'straining' noises when firing up. Any ideas or quick fixes to suggest as to what could be causing this before I get someone in?
Thanks.
theres not a lot you can do other than check pressure.
your problem is either fan pcb or air press switch
pcb retails at about£200, so i would get someone out who will get the diagnosis right because an aps is about £30
worcester do a fixed repair including parts (£250) so dont pay more than that
was at a ladies house yesterday who who paid someone £420 for a pcb change on a a junior ( nice money if you can get it)
Thanks Boilerdoktor - just a slightly random question - is it common for the pressure gauge to fail on these boilers?
So what you mean is Worcester can put a £200 RRP on a part that costs them a few quid to make, but an independent engineer has to pass it for cost, fit it for a pittance and do the call backs FOC if it fails.
Yes they become blocked thus not sensing correctly or at all. What pressure is it giving?
Hi, It was showing adequate pressure (1.5ish) but I have just put the pressure up to 'max' and all the noises have stopped and it seems to be working fine. Could an underpressured system be the cause of the initial symptoms I described?
Thanks again.
2.5 is too high, you have an expansion/prv lifting as a result problem. I guarantee you will be back asking for more advice :roll:
Thanks Gas2Air.
The pressure sensor is a bit funny. It doesn't move straight away e.g. if I put the pressure up now it won't register any change for a while, if at all. Are these a big job to change/unblock to ensure I am getting a correct reading?
Thanks again.
